sn0border88's SAS Thread | Page 27 | Ford Explorer Forums - Serious Explorations
WARNING: This swap will be longer than bmxking's :eek:
Thanks to tig for a real steal that I couldnt pass up ($50), it all started with a d44 from a 73' Bronco. This means its drum braked, coil sprung with LP housing complete hub to hub with r/a's.
But, its matching width. :D
Its in great shape as far as EB axles are concerned. It has 3.50's which upon inspection are in PERFECT condition. Not one chip on any of the ring gear teeth. Also the rust isnt too bad, its simply surface rust, nothing damaging. Also most of the bolts so far are coming off very well, only breaking a few. Not bad for 31 years of rust.
So far in the plans are yukon 4.88's with full spool or lincon locker. Disk brake conversion VIA junkyard or broncograveyard, rear XJ 8" lift leafs and heimjointed crossover. To complete the swap ill be getting new cromo shafts front and rear with a new 5on5.5 bolt pattern for the 8.8 and 4.88's with a detriot. Also rounding it out are some new rubbers, either 35" boggers or MT/R's on 5on5.5 steelies/beadlocked pending on the DD status upon completion of the project. And, if it is no longer a DD when I finish, the top is coming off. :eek: :thumbsup:
EDIT with final prices
Upon completion it now had a Fullwidth d44/9" with 36" TSL-SX, 5.13 gears spooled rear and many other goodies.
Prices:
Gears D44/9" 5.13: $150 from PBB
D44 Master Install: $109.99 from PORC on pirate
9" Master Install: $89.99 from PORC on pirate
D44 Carrier: $60 Ebay
9" Spool: $129.99 from PORC on pirate
1976 f-150 Highpinion Drum Brake D44 : $85 from Junkyard
D44 Disk Brake Outers: $50 from Junkyard
1978 F-150 9": $50 from Junkyard
5 on 5.5 Rims: $20 from Junkyard
4 36x12.5x15 TSL-SX: $ 250 from Pragon Board
1 36x12.5x15 TSL Radial: $18 from Junkyard
Shocks: $100 from Jeff Daniels Jeeps
D44 Spring Perch: $20 Jeff Daniels Jeeps
U-Bolts (Custom) : $30 from local u-bolt shop
Brake Pads/Caliper: $31.77 National Auto
Leaf Spring Hardware: $48 Jeff Daniels Jeeps
Replacement A4LD: $65 Junkyard
Conversion U-Joint: $25 National Auto
Extend Brakelines: $73 from local brakeline shop
Steel: $56
Without what I paid those who helped, plus the gear installs I have about 1,500 into this.
Scrapping the TTB: PRICELESS
I was wondering what the point of cleaning and pimping a rear 9" and then a rockwell up fornt would have been kinda wierd.
anti wrap bar is IN.
tube tranny x-member is IN.
After 5 hours working alone, I got the whole thing done in one shot, flexed and tested and it all clears. Fawker weighs about 30-40 pounds 6' 3/8 wall tube, ~2sqft 1/4 plate, 1 1/4" solid bar and quite a bit of welding.
No, its not going to break. :D
Pics tomorrow.
BEEF:eek:
And with this, I announce the retirement of emily rose.
Rear main seal is going, tranny is going, body is in bad shape, bent another leaf spring, ect. I dont want 4 doors, I dont want 4 seats. I dont want front leafs, I dont want leafs at all. I have realized that this truck will not hold up to my pissed off hillbilly driving style, and its simply not worth the effort needed to make it do so.
I will have one last run july 26-27 then its getting dismantled and sent to the scrapper. Axles and tires will be sold/traded for 1 tons.
New project will be a pickup, either a 60's willys or a MJ
Sorry to hear that, but good luck with the new project eh.
Sorry to hear your putin emily down, but on to bigger and better, and in your case more durable things i guess
you going to be doing a part out by any chance?
YOU ARE NOT ALLOWED TO PUT THAT POOR THING DOWN, YOU HEAR ME?!?!?!?!!? She has been thru WAY too much to suffer retirement in a junkyard !!! ARRGgrrbl!!
So then buy it, 3k takes it all. :D
Oh and I made it home in 30 min flat, screw you google maps.
Ya, im parting it all out. Ill get for sale stuff in here soon, right now I already have threads going in rrorc.com, raush creek forums and pirate.
tires/wheels/motor are sold
Heres a link to for sale threads.
http://rrorc.com/forums/showthread.php?t=37658
http://rrorc.com/forums/showthread.php?t=37659
Im also waiting to get a set of 42 TSL's on hummer beadlocks once I get full payment for the tires. And im trading my 44 for a 60 from a 79 f-350.
Plans for the new project.
1960 Willys Pickup
351W with 4x4 cam
c6 with manual VB
203/205 doubler
D60 5.13 ARB/ 9" 5.13 Spool Full floater outers.
3link front/4 link rear
2.5 airshocks up front, undecided on the rear. Maybe 2.0 airshocks
42" TSL
Extended wheelbase to 105-110"
Boatsides/cage/bobbed bed.
But thats all a long way down the road.
I'm interested in the 9" axle. Let me see how far It is to drive.
Its official now, body and frame were stripped and sent to the junkyard.
It was fun while it lasted, but im glad to finally get rid of all the demons.
I never did post pictures of my fuel cell, here it is.
Sump bent and tacked together
Welded
That cell came out hot! :eek: :cool:
Suuuuper hot!
Are you on the wrong side of the road?
Now that i think about it, he's taken the picture out of his driverside mirror. Sorry :D
