sn0border88's SAS Thread | Page 28 | Ford Explorer Forums - Serious Explorations
WARNING: This swap will be longer than bmxking's :eek:
Thanks to tig for a real steal that I couldnt pass up ($50), it all started with a d44 from a 73' Bronco. This means its drum braked, coil sprung with LP housing complete hub to hub with r/a's.
But, its matching width. :D
Its in great shape as far as EB axles are concerned. It has 3.50's which upon inspection are in PERFECT condition. Not one chip on any of the ring gear teeth. Also the rust isnt too bad, its simply surface rust, nothing damaging. Also most of the bolts so far are coming off very well, only breaking a few. Not bad for 31 years of rust.
So far in the plans are yukon 4.88's with full spool or lincon locker. Disk brake conversion VIA junkyard or broncograveyard, rear XJ 8" lift leafs and heimjointed crossover. To complete the swap ill be getting new cromo shafts front and rear with a new 5on5.5 bolt pattern for the 8.8 and 4.88's with a detriot. Also rounding it out are some new rubbers, either 35" boggers or MT/R's on 5on5.5 steelies/beadlocked pending on the DD status upon completion of the project. And, if it is no longer a DD when I finish, the top is coming off. :eek: :thumbsup:
EDIT with final prices
Upon completion it now had a Fullwidth d44/9" with 36" TSL-SX, 5.13 gears spooled rear and many other goodies.
Prices:
Gears D44/9" 5.13: $150 from PBB
D44 Master Install: $109.99 from PORC on pirate
9" Master Install: $89.99 from PORC on pirate
D44 Carrier: $60 Ebay
9" Spool: $129.99 from PORC on pirate
1976 f-150 Highpinion Drum Brake D44 : $85 from Junkyard
D44 Disk Brake Outers: $50 from Junkyard
1978 F-150 9": $50 from Junkyard
5 on 5.5 Rims: $20 from Junkyard
4 36x12.5x15 TSL-SX: $ 250 from Pragon Board
1 36x12.5x15 TSL Radial: $18 from Junkyard
Shocks: $100 from Jeff Daniels Jeeps
D44 Spring Perch: $20 Jeff Daniels Jeeps
U-Bolts (Custom) : $30 from local u-bolt shop
Brake Pads/Caliper: $31.77 National Auto
Leaf Spring Hardware: $48 Jeff Daniels Jeeps
Replacement A4LD: $65 Junkyard
Conversion U-Joint: $25 National Auto
Extend Brakelines: $73 from local brakeline shop
Steel: $56
Without what I paid those who helped, plus the gear installs I have about 1,500 into this.
Scrapping the TTB: PRICELESS
Me too. I still remember trailering the motor home from Jeff's house before I tore into it.
I still have the motor, it was supposed to be sold to a guy from the RRORC board but we cant work out a good time to get together now that im in school so im just gonna end up scrapping it.
