oleexplorer
- August 15, 2011
- Pittsburgh PA
- 1994 Ford Explorer
I know wat type of trans fluid to use but wat brands are you guys using that you find runs the best. By that i mean dissapating heat. Been lookin into amsoil. Also deep pans only found one type but it was finned and added 3 quarts. I am adding a filter kit that taps into the cooler lines it has a temp sensor in it mounts anywhere and uses a fram number ph8a filter. Perma cool made it. Easy way to install a gauge add some extra fluid and also change a filter regularly which when filled will help keep trans fluid cleaner
