exploreral
- September 12, 2002
- Lisbon CT
- explorer
Where and how much do they usually go for?
If you can get that motor to fit in the engine bay, you have the skills for a solid axle swap.i want to be able to put in a 1999 ford 7.3 diesel
if i know any shop in my area i would call them right now most shop are closing in my area do to the economyFind an off-road fabrication shop and pay them many thousands.
i just want to be different from everyone elseIf $$$$ was an object we woudlnt be building late model Explorer's into rock crawling beasts........
Thats why I have a BII!!!!! hehehehe Everything I have put on my truck is eaitehr used or rebuilt from junk yards and late model Explorer's...it's cheaper that way....I helped a friend pull a D44 twice now for under $200, however once they are cut down, geared, and fitted with new ball joints, cut axle shaft, bushings, etc you are looking at $3000 just for the D44, then you;ve got the rear to deal with, and installation....so the D44 conversion is a BIG step....helps if you do all your own work....
