I did check fuse 83 in the under hood fuse box; it looked fine, continuity checked OK and had 12.5 volts on both sides of fuse in the box. Will need to check if voltage reaching the blue/red wire, then the gray/yellow wire and get back to you. Thanks for the advice.
