Trifectice
- April 19, 2024
- Denver, CO
- 99 5.0 mountaineer
So I am new here and I picked up a mess of a project a couple months ago. Someone has put a 99 mountaineer 5.0 and 4r70w trans into a 98 ranger. Long story short the truck wouldn’t start after sometime and I picked it up for a steel. Since getting it, I have swapped out the fuel lines, fuel rail and fuel pump in order to get it working again and it was running as long as an OBDII was plugged in. Since then, the truck won’t start even with the OBDII plugged in. From my research, I’ve come to the conclusion that it has been a pats issue that has been progressively getting worse. (Note: the steering column ignition ECU and gauge cluster are all from the donor mountaineer) over the weekend I will be trying to reprogram two new keys to the ECU to see if this alleviates my issue if it doesn’t, I am thinking about swapping to a 97 explorer ECU and wiring harness. I would love to hear yall thoughts on this potential solution. It would also give me the opportunity to clean up the mess of wiring the original owners left.
