Showard
- January 4, 2022
- St Louis Missouri
- 2006 Ford Explorer 4.0 v6
Rubber burning smell coming from engine bay and vents. Heat is minimal and when accelerated the heat returns to “normal” but drops again when you come to a stop.
Background: noticed a burning coolant odor after having transmission replaced. Ignored it for about a month since it wasn’t overheating and got on the mechanics books to repair. The day before I brought it in the radiator cracked. Got the radiator replaced. Then noticed the temp gauge was all over the place and it was overheating. Replaced the thermostat apparently it was cracked in half. That fixed the over heating issue but then it was leaking coolant. Used some stop leak, didn’t do a damn thing. Brought it back for a 3rd time and had the housing replaced as it cracked also. No more leaks but now the heat is minimal unless I accelerate and the is a burning rubber smell coming from the vents/bay. Getting pretty cold here so noticed some sort of belt being squeaky for quite awhile before going away.
My thoughts are a belt/pulley issue for the burning smell and maybe a bubble/clog for heat.
Any advice? Going to a different mechanic or repairing myself as soon as I can spare my daily.
