Replacement PCM programing keys 2010 4.0
2010v6Mounty
Modesto, CA
2010 Mountaineer Base V6
According to my mechanic, my PCM is preventing my AC compressor from turning on so it needs to be repaired or replaced. I found online retailers selling refurbished PCM's that they can program with my VIN, but I will still have to have the keys programmed. I only have one key and it looks like I will need two. My question is if I have a new key made before I swap the PCM will I be able to program the PAT system my self or would I need a locksmith to do it? If I need a locksmith should I just swap the PCM first then have a new key made and both programmed at the same time? Another questions is, is it worth it to have the seller program my VIN or should I just buy a used PCM for half the price and have the VIN programmed and the keys at the same time? Thanks in advanced.
