imp
- November 12, 2009
- 59 Ranchero F250 D'Line
PCM suspected, I ordered a new one, which came with 2 "pre-programmed" (PATS) keys. Had teeth cut by locksmith duplicating my oiriginal keys. Installed replacement PCM, inserted key, PATS indicator winked properly, started engine. Other key won't start engine. The explanation which came with the PCM for programming, I did not follow. Stupid me. PCM was not the issue after all.
OK, not wanting to have only one key, I put the original PCM back in, had the 2 original Ford keys we had always used, 2 of them, started engine normally. Other key WILL NOT start engine! WTH did I do wrong??
imp
imp
