- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
The filament that I used is flexible. I made a couple of these rubber faucet covers, and found out that it's only flexible when it's very thin. It won't flex that much if you make it too thick.
There are a couple of all in one scanner/3D printer combos but from what I've read they still aren't completely perfected to make a perfect scan without tweaking the image on a computer first. The companies recommend covering the scanned object with some sort of powder or wax to help eliminate glare & reflections to increase the resolution. Most people either use a dedicated high resolution scanner or just draw a 3D model with a CAD program after taking measurements of the original object. There's a way to use a smartphone camera as the imager with the proper app but I don't know if the resolution is that great.
Any object could be sanded. I've read that acetone is used to smooth a rough object but it didn't seem to do anything for the rubber material that was used. Maybe it's only good for standard ABS or PLA which I haven't tried yet.
