MuscleJunkie
- April 14, 2007
- '00 Ford Explorer LTD AWD
Don’t overspin your Powerdyne Supercharger!
After a couple thousand miles this is what happened to my Powerdyne (Ford Motorsport SVO) Supercharger on Big White. The bearings were completely destroyed as well as the stock impeller
The Ford Motorsport SVO kit for the 2nd generation Ford Explorer comes with a 3.1” pulley. The stock pulley will spin the blower at 38370.97 rpm at the 6,000 rpm redline which is within the max of 38500 rpm given by Powerdyne. Since the cam in the 5.0 Explorer is different than that in the Mustang - most recommend shifting at 5400 rpm or lower. At 5400 rpm with stock pulleys, the blower is only spinning 34533.87 rpm
When I installed my new Supercharger, I opted to instead go with a 2.8” pulley from @928motorsport_official This pulley should spin the blower at 38233.93 at 5400 rpm.
I did NOT verify the pulley size when I received it from @928motorsport_official and it turns out that the pulley was actually 2.86” which was spinning the blower at 37431.82 rpm at 5400 rpm
After some initial dyno runs and upgrades, I decided to purchase a 2.7” pulley from 928 Motorsports (again I did not verify the size upon receipt which was my mistake). This pulley should have been spinning the blower at 38181.48 rpm at my now lowered 5200 rpm shift point.
The big problem was the 2.7” pulley I bought from 928 Motorsports was actually 2.65” which means I was spinning the blower at 38901.89 rpm at 5200 rpm and over 41000 rpm when manually shifting higher than 5200. Again, my fault for not checking the pulley size and my fault for spinning the blower higher than 38,500 rpm.
So the lesson here is always verify the pulley size before installation regardless of what is advertised. @928motorsport_official sold me two pulleys that were differently sized than advertised - they claim their pulleys are “cut to .001 accuracy” - the two I received clearly were not. Also do not overspin this blower higher than 38,500 rpm or your blower will end up like mine.
Fortunately I am having the Powerdyne rebuilt by Jon Bond Performance with an upgraded billet impeller that should flow better than stock as well upgraded belt + bearings. Stay tuned!
