V8BoatBuilder
Transplanted Bostonian
- November 4, 2002
- East Brunswick, NJ
- 97 Mountaineer V8 4x4
Ok, there is a slim slim chance your driveshaft is the problem. Try turning the flange/socket on the t-case with the truck off. If it is still stuck, we can say with 100% certainty that your case is the issue.
The caps on the can was just to let you know that it's an OK temp solution.
As for a new case, a junkyard would be my 1st choice. You could get a direct replacement, or swap to a manual case. The former is the easiest to do, can be done in a day if you don't mind lifting the truck up.
T-case removal is not hard, and that case is not too heavy. Basically it runs as follows:
1) Remove both driveshafts, wiring harness and vent hose. Drain the case.
2) Remove 5 bolts that hold the case to the transmission. You might need to remove the center console and go through the plate in the floor to get to a few of them.
3) Remove case, it slides back off the transmission shaft with some good persuation.
4) Clean up the transmission flange, and new t-case mating surface.
5) Apply a good bead of RTV.
6) Stab new t-case is place on transmission shaft.
7) Insert and torque 5 bolts.
8) Reinstall driveshafts, wiring, vents
9) Fill with fluid.
Try www.car-part.com for a new case. All you need is the case, you can re-use your shift motor. I'd expect to pay around $200. Although you might get a freebie motor...
9) Fill with fluid.
