J
JCMAC
I have a 97 Eddie V8 AWD Explorer which I like very much, except that I have become fed up with the consistently higher rpm shifts out of first grear and into second gear that are rarely less that 2500rpm at a very conservative throttle setting. I have test driven a couple of other V8 explorers and they behave the same as mine.
Question one, does the PCM control the shift RPM of the transmission, if so why did Ford select such a high shift rpm, its not as though the motor can't handle second gear...
Question two; If the PCM controls the shift speeds then does ford have a revised program the could be downloaded to the PCM. Also, why does the tranny take so long to respond to a downshift request at low speed (to go from 2nd to first).
Are does anyone know if there atermarket or other solutions available.
Thanks!
John
Thanks!
John
