Glad you got it working. For the heated seats I have always just forgone installing it due to uncertainty with how it is controlled. It could be that when putting power to the heated seat wires that the seat just goes to a certain temperature and stays there until toggled off. If thats the case then hotwiring the heated function to an on/off switch would work just fine. However I think it is more likely that some module regulates the heat and without everything being hooked up to the correct modules that hotwiring will result in a heated seat element that overheats. I have not found someone who can confirm how it is regulated and for that reason I have never hooked it up. If you have sync already and upgrade to the touchscreen and all the Explorer body harnesses then it will most likely time and money, that sounds like a lot of work for a warm bum.
