Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
Alright! I've got all my tools now, picked up my air compressor and impact wrench with all the accessories to go with. I love that impact wrench, I can't believe how easily it pulls tight nuts and bolts off. It ripped the crankshaft pulley bolt right out with little effort.
On to the repair... I've removed my water pump, I've pulled the bolts out of my accessory brackets for my PS pump and my AC pump and pulled those a few inches out of the way. I'm pretty sure I've removed all the bolts necessary to remove the timing chain cover including the 4 in the oil pan. From what I understand the TC cover needs to come forward 3/8th of an inch before it can come off. I've pried a little at the top and can make a small gap between the block and the cover but that's about it. Does anyone have any tips on removing the cover as far as the best places to pry at it, I also understand there are two dowels that hold the cover in place. The only helpful thread I came across was by @rizzjc from back in 2007, I'm just wondering if anyone has any more info, any advice would be much appreciated!
