- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
Update to this thread. Sarah has been DD this little truck. She needs more towing capacity but doesn't want to let it go. The rear main seal is leaking, and the valve cover started leaking again a few months ago. I'm not fighting that thing again.
I was replacing the front pads and noticed the upper control arm ball joints were shot. After a mad scramble for parts, I located everything at Napa.
Southern California trucks are usually easy to work on, took me about an hour to remove the upper control arms and lower ball joints. 15 minutes to inspect and repack the wheel bearings. New upper control arms bolted right in. Driver side lower ball joint gave me trouble. It didn't want to seat against the flange. I had way too much pressure on the ball joint for comfort and it wasn't moving. I could almost hear my Dad say "Hit it with a hammer". I tapped the control arm next to the ball joint and POP!, sucker seated. Thanks Pops. I miss that guy. I hadn't worked on a 2wd with stamped control arms in a long time and had forgotten the old hammer trick to release tension.
It's all back together again and should be good for another ten years after I get it aligned.
