toobladink
- August 29, 2023
- Spokane, WA
- 2000 4WD XLT
About time I made a post, I'm finally getting serious about what I own! I bought a 2000 XLT almost eight years ago now. Got it as my first car, and it's my only car. It's done everything I've wanted, and I've pushed it beyond what I thought was even thinkable on a camping trip once when a friend said I would be fine, and once I got a taste of that, I haven't been able to stop thinking about it. I have some goals with what I want to do, and I've been reading for a while on what I should or should not do. But I still have some questions as some stuff I've been looking at is old and the other stuff I'm curious about just doesn't have an answer or I'm curious about opinions. Currently sitting at 165k miles, so my first question is, how many more miles should I expect out of this? I've seen numbers upwards of 250k and my dad's F250 from the same year went all the way to 300k, so I'm feeling hopeful that quality transferred over and I'm only halfway.
First I want to confirm, is 31x10.5R15 the biggest tire size you can fit on a stock 2ng gen? I don't want to lift as I like my casual ride quality for the roads. I'm not super interested in doing stuff that would need a lift, I think my clearance is fine and with the tires I have on now, it'll give me a little over a half inch of gained clearance anyways. Found this info on a 15+ yr old post so I gotta double check.
Some lights went out in my instrument panel. I want to replace these and found some LED replacements on ebay. I imagine these will still dim the same and I don't need anything special? Also found they come in colors - are there any that look cool? My numbers are almost green so I was thinking just getting the white/yellow ones to maintain that. But like if orange or green gives it a cool look, would love to see some pics!
What should I be weary of maintenance wise? I mean this car is nearly as old as me and I've had ACL replacement, but literally nothing major has happened and I want to do some preventative maintenance on some stuff or know what I should check. I've replaced the brakes once a few years ago, spark plugs and filters about 10k miles ago, regularly change the oil/fluids, and tires are about 6 years old now (still haven't hit their 50,000 mile mark, I drove very little in college). Any belts I should look at for excessive wear or anything? I was thinking maybe the shocks are getting worn (they certainly feel like it) but keep reading if you were gonna say something about that...
I was looking at replacing the shocks to give me adjustable ride quality. Typically my use cases for this car now are road trips, and then I pull off into some forest roads and drive around til I find a spot I want to camp. The Rancho RS9000XL shocks look pricy but they look like they could do what I want. For anyone that has these, are they easily adjustable on the explorer? Is it worth the extra cash over the RS5000 you think, or just slightly noticeable and more of a marketing thing? I just really like the thought of turning a little knob to make driving on those washboard roads smoother so I keep my teeth.
Also to help improve ride quality, I was hoping that changing my tires and rims could help. Currently I have 16inch rims, but was thinking of moving to 15x8 with like a -20mm offset. Will the offset increase wear in the same way spacers do? Or is that a myth about spacers? I want a slightly wider wheel base for cornering and increased side walls so when I do purposely deflate them, it has a little more room to work with.
Lastly, this thing is kinda noisy. I don't like how damn loud it is when driving 70MPH on the interstate. I don't speed because usually I'm with friends and going faster means talking louder, or I gotta turn the music up and when I do that, the door panels vibrate. To kill two birds with one stone, I was reading about DEI Boom Mat spray. I'm almost positive it will help with the door panel vibrations, will it do anything for road noise or are there areas I can apply it where it could help in that regard? I know decreasing sound by like 1-2dB doesn't sound like a lot but if this spray can do that, I'd be super happy since every 3dB is perceived as "twice" as loud by most people.
