07EddyB
- November 18, 2011
- Bowling Green, KY
- 2007 Ford Explorer 4.6 V8
I decided to try to update SYNC tonight - haven't done it since we bought the Explorer two years ago.
I have WiFi in the garage so I hook up a battery tender and get to work.
Hmmm - it's already connected (I seem to vaguely recall we hooked it to the WiFi shortly after buying it) and auto updates is on. OK - check for updates. Current version is 21194_PRODUCT. I think it came with that but checking for updates results in it saying I'm up to date.
Create an account on the Ford site - check for update there and it says one is available. When I select update by WiFi it just gives me instructions on how to do that. I go through it again and it still says it's up to date. Was hoping going through the web site would push it out but that doesn't seem to be the case. Not sure why the web site says an update is available but it won't pick it up.
To top it off - at some point during this process my lights started staying on. Well - that's weird. I opened the garage door and started it hoping that would reset things but no luck. Checked the light switch - maybe I hit it with my knee? It was on the automatic setting - turned it to the off setting and nothing happened - turned it back to the automatic setting and the lights went off.
Nothing in SYNC seems to be broken so I'm just going to let it be. I'll check it occasionally and see if it updates on it's own.
Edit - I think I did accidentally hit the switch - hard to explain the sequence of events there but I no longer believe any gremlins were present.
