tcbarney
- December 20, 2001
- Canton, GA
- '96 XLT 4x2
Here's the simple question:
What is the right lube to use on the caliper slide pins on my '96 XLT?
My Haynes manual says something like "at the time of printing, there wasn't a replacement for this stuff, so don't wipe it off..." I THOUGHT it was referring to the caliper pins, but may be mistaken.
I've got a tub of hi-temp disc brake wheel bearing grease (Coastal brand, gold colored) that I've been using on my Miata for years to lube the pins, and just used to pack my bearings on the Ex. Will that work fine on the Ex?
I'm having to replace the driver's front caliper bracket. When I removed it to change the bearings, the top bolt stripped out the threads for some reason. I got a replacement bracket at the junkyard, but will need to clean out the holes for the caliper pins and make them all slidey again, as they are a little stiff and one has a bit of rust.
Any tips for cleaning out those holes? I planned to swab them out with brake cleaner, and maybe buff the inside with a polishing pad on my Dremel to get rid of the rust.
Thanks.
Thanks.
